Discussion topic: Sky Q box is dead
This message was authored by: PaulSH
Sky Q box is dead
Hi, my Sky Q box refused to show any picture or sound at all so I've gone through the following steps;
Switched off at the mains, waited 5 minutes then switched back on again (more than once)
Forced a software update (switch off at mains, hold down standby button then switch back on)
Replace the hdmi cable
Nothing has worked and the only lights showing on the front are the red recording light (we're not recording anything) and the green standby light.
Is it dead or are there any other things to try?
Thanks, Paul
Re: Sky Q box is dead
Thanks, Paul
@PaulSH when the green light is on try pressing the following buttons on your remote the home button followed by 1080 then the home button again
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for PaulSH
Hi @Laing1 thanks for your reply.
Sadly that didn't work.
I still have the red light and the green light both on.
Paul
Paul
@PaulSH sounds like you may need to speak to Sky I can escalate this to them but the ealiest they may contact you on here will be tomorrow or if you want to speak to someone tonight you could call them
Avatar for PaulSH
Thanks, I don't mind waiting until tomorrow.
Thanks for your help
@PaulSH I have escalated this to sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
This message was authored by: Lisa-P1987
Thanks for escalating this. We’ve sent PaulSH an invite to chat.
Lisa - Sky Tech Team Expert
Avatar for PaulSH
Hi @Lisa-P1987 I can see the DM telling me you're initiating a chat and have opened the chat pop up but its empty
Paul
Avatar for PaulSH
24 hours later and still no repsonse?
@PaulSH
Press the blue/red chat bubble in the corner of your forum page. It should still be active.
Once that speech bubble appears you only have 48 hours to join the private chat or it will close automatically. If you fail to respond to each chat reply from Sky within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky are not instant so you’ll need to regularly check the chat regularly.
Update - spoken to PaulSH and have resolved the issue with an engineer after some troubleshooting and checks. 🙂
Avatar for PaulSH
@Lisa-P1987 if it was you I have been chatting to in the live chat then thank you very much for being so helpful and understanding. It was very much appreciated.
Paul
