Discussion topic: Sky Q box humming noise
Message posted on 29 Aug 2023 09:11 AM
Humming noise coming from sky Q box
Message posted on 29 Aug 2023 09:16 AM - last edited: 29 Aug 2023 11:01 AM
Re: Sky Q box humming noise
They do make a noise (spinning hard disk/fan) - but if it's excessive you may need a box replacement.
Message posted on 29 Aug 2023 09:30 AM
@Mark1418 wrote:Humming noise coming from sky Q box
It can either be the hard drive or the fan. Turn the box off at the wall and make sure there's not excessive dust gathering round the vents on the underside of the box. Blow some air into the fan to make sure it's not getting clogged.
Also, try applying a bit of pressure to the top of the box. Does that stop the hum?
Message posted on 22 Aug 2024 11:38 AM
I have the same problem with a noisy gym coming from the Sky Q box.
applying a small amount of pressure to the top of the box worked a treat. Thanks
Message posted on 19 Sep 2025 05:23 PM
I have had a supposed new box delivered and there is a humming sound coming from the box and it won't connect?
Message posted on 19 Sep 2025 05:28 PM
@Elise+Mitchell wrote:I have had a supposed new box delivered and there is a humming sound coming from the box and it won't connect?
It won't connect to what? Your TV? Your broadband? This is a Q box, not a Stream puck, yes?
Message posted on 19 Sep 2025 05:44 PM
We have internet connection but not network connection
