Discussion topic: Sky Q box hard drive problem
Message posted on 05 Jun 2025 09:52 AM
Turned on TV and Sky Q box has a problem with the disk drive. I have followed the instructions to reset the hard drive, all to no avail. I would like to get Sky to come out and replace the drive.
Message posted on 05 Jun 2025 10:17 AM
Re: Sky Q box hard drive problem
They will replace the whole box with a doorstep swap
make sure you keep your viewing card AND swap power cables as there are two types.
you'll have to go through the troubleshooter
Message posted on 05 Jun 2025 10:18 AM
See here: https://www.sky.com/help/articles/sky-q-hard-drive-errors
Sky will not replace the drive, they will arrange a box swap. Remember to remove your viewing card before you give the courier your old box.
All recordings are lost, you can re-download any purchases.
Message posted on 05 Jun 2025 10:19 AM
They don't replace the hard drive. They replace the whole box, usually by a doorstep box swap.
Try following this link. It should lead to a replacement box if needed https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
If you do need a new box remember to remove the viewing card from the faulty box.
Message posted on 05 Jun 2025 10:47 AM
Thank you all very much for your prompt and accurate replies. I eventually got through to a Sky helper who has arranged a new box to be delivered.
Thanks again everyone 😀
Pete S.
