Discussion topic: Sky Q box freezing up
Message posted on 28 Apr 2023 01:04 PM
Can anyone help.
My Sky Q box was often freezing up and a quick disconnection of the plug for 30secs or longer and restart would fix it.
I had a Sky engineer around recently regarding my broadband and I mentioned it to him and he said that my amount of recordings on the Sky Q box was quite high at 92% so I whittled it down to around 45% and then it was behaving itself.
Only for the last few days it has begun to go the same way and after one of my "plug out" resets it done a software update....and ever since then, I can't get any TV for longer than 1.5mins and then it freezes. Couldn't even be able to tell you what software I'm on as it freezes up.
Any ideas?
Many thanks in advance.
Message posted on 28 Apr 2023 01:08 PM
Re: Sky Q box freezing up
@SashE wrote:
Can anyone help.
Any ideas?
Hi @SashE
See if it is on long enough to try a Reset Settings in the Q box hidden menu.
Failing this try the recovery procedure in the following link
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Message posted on 28 Apr 2023 01:29 PM
Thank you @oldfella for that. I'll give that a try and see how I get on.
Cant even get past the black screen of "your sky will restart in a few minutes" after recent reset attempt.. Know there's a blue screen to follow at some point.
Message posted on 30 Apr 2023 01:40 AM
So I tried the reset procedure and after a while sitting there idle, it appeared to work.
Reconnected my remote and was behaving itself but then come around 3hrs later, it froze up on me again.
Had to unplug and left out for a fair bit and then restarted.
Would this be a possible indication that the box is starting to struggle a bit?
