Discussion topic: Sky Q box freezes
This message was authored by: R4EAD
Sky Q box freezes
Every day my Sky Q Box freezes.
I unplug it and go through the restart schedule and sometimes it's ok for the evening but sometimes freezes and the blue light spins and however long it's left it stays frozen unless unplugged.
YouTube seems to be a particular problem.
Any thoughts?
Re: Sky Q box freezes
Any thoughts?
Hi @R4EAD
Try a reset settings, see if that helps.
Reset Settings in the Q box hidden menu.
Avatar for R4EAD
Thanks very much.
I have done the reset and hope it works!
