Discussion topic: Sky Q box failed recordings
This message was authored by: JT955
My sky box has started to constantly fail to record and it says power failure. Also If I try to watch previous recordings it says no longer available. I have to switch box of at mains and restart each time. The box will then work ok
This happens on average every couple of days. I have checked that I have the correct software on the box
Re: Sky Q box failed recordings
Hi @JT955
Avatar for JT955
So I tried the suggest fix and it seemed to work for about a week and the problems started again. Having to reset the box every couple of days and missing recordings that I wanted.
This message was authored by: Dixie1962
I just tried this but the recordings are still not working
This message was authored by: Jons0
I'm having the same problem, multiple occasions when recordings are failing because of  'power failure' . I don't use my sky q box that often and the power failure problem definitely seems to occur if the box hasn't been used for a week or more. My solution has always been to unplug and then restart but it is tedious that there doesn't seem to be a better solution.
