Discussion topic: Sky Q box errors
Message posted on 23 May 2025 05:57 PM
Sky Q box errors
Is any one having trouble with their sky Q box not working again? This is the second time this month there is no signal to the box. The last time it went down for days.
Are we getting a refund on the days we do not have access?
Message posted on 23 May 2025 06:01 PM
Re: Sky Q box errors
No signal or no satellite signal as they are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
