This discussion topic has been answered Discussion topic: Sky Q box drops
Message posted on 08 May 2025 08:37 AM
My sky Q box keeps dropping internet connection. Can anybody help me please?
Message posted on 08 May 2025 07:02 PM
Thank you so much. I tried all these things and when I eventually got signal to my Sky Q box I reset it through the sky settings which seems to be fine for now. Thank you again.
Message posted on 08 May 2025 09:16 AM
Re: Sky Q box drops
Message posted on 08 May 2025 04:12 PM
Re: Sky Q box drops
Hi @Zimdiane
Try completely resetting your connection.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
