3
This discussion topic has been answered Discussion topic: Sky Q box drops
This message was authored by: Zimdiane
Sky Q box drops
My sky Q box keeps dropping internet connection. Can anybody help me please?
Avatar for Zimdiane
This message was authored by: Zimdiane Answer
Re: Sky Q box drops
Thank you so much. I tried all these things and when I eventually got signal to my Sky  Q box I reset it through the sky settings which seems to be fine for now. Thank you again.
This message was authored by: Dazzasky
Re: Sky Q box drops
They a reboot of your Q box and router to see if it resolves the issue @Zimdiane
Re: Sky Q box drops
Hi @Zimdiane
Try completely resetting your connection.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for Zimdiane
Re: Sky Q box drops
Answered - Go to Answer
