This discussion topic has been answered Discussion topic: Sky Q box constantly freezing and needs reboot.
Message posted on 10 Oct 2026 01:55 PM
Sky Q box is constantly freezing. The only way to get it back on it's to unplug and plug back in. Software is up to date. Very inconvenient. I have had this same box for a very long time. How do I get a replacement?
Message posted on 10 Oct 2026 04:45 PM
@Spoonsey wrote:Sky Q box is constantly freezing. The only way to get it back on it's to unplug and plug back in. Software is up to date. Very inconvenient. I have had this same box for a very long time. How do I get a replacement?
Thank you. I'll give that a go.
Message posted on 10 Oct 2026 03:19 PM
Re: Sky Q box constantly freezing and needs reboot.
Hi @Spoonsey
Have you tried a Reset Settings in the Q box hidden menu.
