Discussion topic: Sky Q box audio bbc one Dolby issue
This message was authored by: TrebleTA
So I have notice some audio problems before, but have noticed as I watch the womand football on bbc 1, there is like interference, this is on dolby and dolby plus, yet normal it's clear. Do the BBC even send a dolby siginal. I've only noticed this on bbc one.
P.s as the commentators speak you hear it, behind there voice.
Vodafone FTTP. Sky Q UHD to Samsung QE55S95BAYXXU , Sky Q Mini.
Re: Sky Q box audio bbc one Dolby issue
Hi @TrebleTA   I'm afraid I suspect it is your equipment, crystal clear here (especially the commentators) and yes it is Dolby Audio - DD according to my Sony TV. Sky Q box set to Dolby Digital Plus.
Avatar for TrebleTA
Level 5 icon
Maybe it's my tv then I have a samsung s95b, only 4 months or so old. I only get it when they speak like a bit of distortion behind there voice.
Avatar for TrebleTA
Level 5 icon
If I watch it live via the bbc app via the sky q box the issue is not there!
Also better picture quility as its via the app.
The current HD feed is 5.1 so maybe your TV has problems with 5.1 sound
BTW BBC1 & BBC 2 HD feeds do vary between  2.0 & 5.1 depending on content
The BBC iplayer app  only uses  2.0 PCM
Hi @TrebleTA   I have just checked, audio via the Sky Q BBC iPlayer is PCM (Normal), no Dolby. If the problem is with commentary on Dolby, then you need to check your centre speaker.
Avatar for TrebleTA
Level 5 icon
The tv has it all built in, no way of checking
Avatar for TrebleTA
Level 5 icon
I put it down too, my tv is to new for the sky q box, and has problems. I can not see it being the tv as it would be all the time. Watching 4k Netflix etc is all fine I only get on live tv on uhd channels and now bbc.
Avatar for TrebleTA
Level 5 icon
My tv model is Samsung QE55S95BAYXXU
I think it was last years top model.
Added to my info.
Avatar for TrebleTA
Level 5 icon
So I've still been having the above issue. I think I may of found a fix. I turn the sky HDMI control to off.
Which I don't get.
