Discussion topic: Sky Q apps freezing
Message posted on 10 Feb 2024 10:59 AM
Sky Q apps freezing
For the last few days my Sky Q apps have been freezing. I have quite a few and it seems to be happening on all of them, making them unusable. I'm lucky as my LG TV gives me access, but I shouldn't have to use it.
Message posted on 10 Feb 2024 11:01 AM
Re: Sky Q apps freezing
hi @Dweller
Might be worth resetting the Network on your Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Message posted on 10 Feb 2024 11:22 AM
@oldfella It's connected to the router via a Powerline. Which given my 1gb connection will be better than wifi, right?
Message posted on 10 Feb 2024 11:55 AM
Hi @Dweller
Powerline is not guaranteed and depends on the condition and complexity of your mains circuit.
When all boxes are connected by Ethernet/powerline you can then switch off all Q box WiFi.
You cannot turn of the main Q box WiFi if you have minis on WiFi
On main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Message posted on 10 Feb 2024 12:01 PM
I agree about Powerline. I did have it test d once, someone had to borrow a laptop with an ethernet connection. I'll try your suggestions, many thanks.
Message posted on 10 Feb 2024 12:05 PM
Hi @Dweller
Assume you have no minis onWiFi??
Message posted on 10 Feb 2024 04:10 PM
No minis. So far so good. Thanks again. If it happens again I will post here.
