Discussion topic: Message: connecting to your sky q box
Message posted on 10 Feb 2024 02:18 PM
Sky Q not connecting: Message: connecting to your sky q box
Message posted on 10 Feb 2024 03:13 PM
Re: Message: connecting to your sky q box
Hi @Tim4
If this is your Main Q box then try a Network Reset found in Q box Home - Settings - Setup - Network.
if it is a Q mini box not connecting
Reboot the mini as above.
