Discussion topic: Sky Q and WiFi non functional incorrect password
This message was authored by: Tris_Horn
My sky and mini boxes and WiFi are not working despite a good old fashioned off and on which usually does the trick. Devices are saying "incorrect password" when trying to connect to WiFi and sky Q and mini boxes are not starting up....via the app all functionality is indicating "ok" and green ticks everywhere but nothing actually working. Any tips?
This message was authored by: ThePope27
Re: Sky Q and WiFi non functional incorrect password
Are you performing a network reset on your Q box? To do so, navigate to Q box Home > Settings > Setup > Network. Choose "Status" and then select "Reset" on the right-hand side. Follow the prompts to connect via WiFi to your Sky router. During the process, you'll be prompted to press the WPS button on the Sky router (not on the Q box, as the network reset will automatically initiate the main Q box WPS). Ensure you press the WPS button on the Sky router, not the reset button
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
@ThePope27
Better
This message was authored by: KO1961
My Sky Q box was always flaky on Vodafone so I hoped changing to Trooli Fibre Broadband
In the past I've tried direct cabling to the Sky Q and Mini Box without much success, the Mini Box has been unusable for months
The connection to the WiFi was perfect for 24 hours but now every time you try to connect the Q STB it's says the password is incorrect
I'm using a TP Link x10 Mesh system with the Trooli Router WiFi disabled
Any help would be grateful received as it's getiting to the point of cancelling Sky
Wire it and disable wifi on the Sky boxes
Sadly no Ethernet cabling near the main box - it seems Sky boxes are reluctant to work with 3rd party routers
