23 Dec 2024 06:22 PM
I have a Sky Q and 2 Sky Mini boxes. My issue is that recently i cant seem
to independently select the channels on my Mini boxes, they are just playing whats on the Sky Q box. When i slect a channel on Sky mini, it then changes the Sky Q box. There is no indepemdence. This didnt use to happen. Can anyone help me?
23 Dec 2024 06:33 PM
Hi @Cathy53
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
23 Dec 2024 07:03 PM
Thanks Oldfella. That has helped. Both my Sky Q and Sky Mini boxes are showing independence. Now I think I have a problem with controllers and my home network...but thanks for the help!
23 Dec 2024 07:06 PM
Hi Best to reset each remote @Cathy53
