Discussion topic: Sky Q WiFi
This message was authored by: edgie700
Sky Q WiFi
Hi all , I've noticed my Sky Q box gives off a WiFi signal ( used a WiFi signal checker app ) Sky Q box is connected to my Sky hub for content , is there anyway of turning off the broadcast signal the Q box sends out but obviously keep it connected to the router ? Thanks
Re: Sky Q WiFi
Enter the engineers menu.
Open the menu, move to settings, hit 0 0 1 and then select.  There will be an option to turn WiFi off.
Avatar for edgie700
Level 4 icon
Re: Sky Q WiFi
Thanks , unfortunately I can't get any home screen or TV guide , looks like WiFi is staying on
Re: Sky Q WiFi
Hi @edgie700
If your main Q box is connected by WiFi to your Router then the box WiFi needs to be on anyway.
You can only turn off the Q box WiFi if it connected to your Router by Ethernet.  In addition if you are using any minis on WiFi the Main box WiFi must also be on.
Exactly what is the issue you are seeing?
Avatar for edgie700
Level 4 icon
Re: Sky Q WiFi
Sorry for late reply , I was just going to turn it off so it's one less thing on my WiFi network, I've not got any other Q mini boxes but I realise WiFi needs to be on to access the home screen menu .
I have got a couple of Q boosters but I'm changing them for the upright newer booster , apparently the Q booster was predominantly for extending the Q WiFi to mini boxes so I'm changing.
Re: Sky Q WiFi
No...  If the box has ethernet connectivity it works just fine.
