Discussion topic: Sky Q Remote
This message was authored by: gerry-4
Sky Q Remote
Can you have 2 Sky Q remotes controlling the same TV & Box?
Re: Sky Q Remote
hi @gerry-4
Yes it can be done but rather convoluted.
Only one can be paired in bluetooth mode (& thus Voice control) - the other(s) has to be IR only
You first pair the one you want to use in infrared only mode (pressing & holding 7 & 9 if needed to reset) by pressing & holding 1 & 3 together & following the on screen instructions
Once paired to the box & TV you reset it to use Infrared by pressing & holding 4 & 6 together
Then you re-pair the one you want to use in bluetooth mode & for voice contro, as above but this time don't press the 4 & 6 after
Avatar for gerry-4
Level 2 icon
Re: Sky Q Remote
Thanks for the reply, not sure its worth it.
