Discussion topic: Mini box won’t connect to main box, says I don’t have required subscription to use, with error mr104
Message posted on 30 Jun 2024 11:22 AM
I've been using my sky q mini box regularly without issue for the last month, but this morning when I turned it on, it has disconnected from the main box and will not reconnect. (I have rebooted both boxes several time and gone through all steps I have seen on sky help forums) whenever I try to reactivate the mini box in settings, it tells me I don't have the required subscription to use the mini box, even though I know i do. The mini box has the error message mr104 (which after looking up I discovered is a network error). I tried resetting my network but the main box says there is no issue with it. I don't know what else I can do, any response is highly appreciated, thank you
Message posted on 30 Jun 2024 11:50 AM
Re: Mini box won’t connect to main box, says I don’t have required subscription to use, with error m
Hi @Samantha51
Try a Reset Settings in the main Q box hidden menu.
Once the main Q box is back up and completely running if you still have the issue complete the following.
First try rebooting the main Q box again and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
