Discussion topic: Sky Q Remote intermittent beeping
Message posted on 10 Apr 2024 08:42 PM
Hi,
my Sky Q remote has started beeping like someone has pressed the finder button on the box every 30-60 minutes.
Everything is working as it should. I thought it might be the batteries, but I've checked and they still have charge in them.
Any idea what's causing this?
Message posted on 10 Apr 2024 08:44 PM
Re: Sky Q Remote intermittent beeping
@Wardinho wrote:
Hi,
Hi @Wardinho
Are you sure it is the remote bleeping and not a smoke alarm with low battery?
Message posted on 10 Apr 2024 08:49 PM
@Wardinho wrote:
Hi,
@Wardinho probably not this but have you checked that the middle Q button on the front of the box hasn't got stuck in
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 12 Apr 2024 12:29 AM
Are you trolling me? Obviously I know the difference between a remote control beeping and my smoke alarm. **bleep**?
Message posted on 12 Apr 2024 07:32 AM
@Wardinho wrote:Are you trolling me? Obviously I know the difference between a remote control beeping and my smoke alarm. **bleep**?
@oldfella was trying to be helpful, you won't believe some of the 'issues' that get raised in this forum that turned out to be simple to resolve. It always helps to rule those out first! (Remember this is a customer helps customer forum).
Have you tried turning your Sky Q box off at the mains to initiate a cold restart?
