Discussion topic: Sky Q Remote TV Pairing?
Message posted on 19 Apr 2024 04:06 PM
I have two remotes for my Sky Q, one is the version with the blue speak button on the front, and the other is the standard remote without the speak button.
The second remote failed so I've bought an identical replacement. It worked with the Sky Q straight out of the box, but I can't get the TV volme to work. I've reset it by holding down 7 & 9 until it flashes, but when then holding 1 & 3 it flashes but nothing comes up on the TV screen, so I can't enter the code for my TV.
Any suggestions please?
Message posted on 19 Apr 2024 04:12 PM
Re: Sky Q Remote TV Pairing?
Hi @Big+Stevie
Message posted on 19 Apr 2024 04:13 PM
Thanks, I;ve tried that but when the remote flashes after holding 1 & 3, nothing happens, with nothing appearigmn on the TV screen
Message posted on 19 Apr 2024 04:32 PM
Assume the TV is on and you are switched to the correct HDMI input for the Q box?
Is the Q box on with green led @Big+Stevie
And did you make sure that the Q box was in direct line of sight of the remote when you pressed and held 1 & 3 together?
Message posted on 19 Apr 2024 04:34 PM
Yes I did all of that. Maybe the remote is faulty, though both the 1 & 3 buttons work as they should, just not when both held down together.
Message posted on 19 Apr 2024 04:54 PM
Hi @Big+Stevie
Check the batteries in the remote. Infrared needs a little more power when using 1 & 3.
Then reboot the Q box.
Then again with the Q box on with green led press and hold 7 & 9 until the led flashes 4 times but do not press 1 & 3.
The remote then will be in infrared mode and need direct line of sight to the Q box.
This should allow you to operate the Q box using infrared.
If it does go to Home - Settings - Setup - Remote control.
Select your remote version and try pairing again. You should be asked to press the 1 & 3 at this stage.
Message posted on 19 Apr 2024 05:37 PM
Thanks for trying to help, unfortunately non of that got it to work. Everything worked with the remote control except when holding 1 & 3, whist the remote did flash to acknowledge the buttons had been held, it didnt bring up the screen to enter the code for pairing with my TV.
I got as far as choosing my TV manufacturer etc, but when the instructions on the screen said to hold 1 & 3, nothing happened.
I'm going to return the remote and order another one.
Message posted on 07 Jun 2024 03:45 PM
Did you ever resolve this issue. Ive just got a replacement sky q box with a new remote so took the opportuniyy to switch my exiting remotes round.
im now left with one remote that works the q mini box but wont pair with the tv. Like yiu inpress 7&9 to reset and then 1&3 to pair and lights flash etc but the onscreen instructions dont come up to pair with the tv.
Message posted on 07 Jun 2024 04:26 PM - last edited: 07 Jun 2024 04:26 PM
hi @Taxman75
After resetting the remote with 7 & 9 & ensuring the LED flashes 4 times you must make sure that the remote has line of sight of the SKY Q box as it uses Infrared until it is paired
Message posted on 07 Jun 2024 04:52 PM
I sent the first remote back to Amazon and ordered another. I cant recall exactly but I seem to remember that after pressing the buttons I didnt get any message pop up, but the new remote then worked regardless.
Message posted on 07 Jun 2024 07:33 PM
Worked out that there is a very easy solution. Go to Home menu, Settings, Set up, Remote control and then use the menu to set up the control manually.
