Discussion topic: Sky Q Recording Light not working
This message was authored by: Austinored
Does anyone has the same issue? Mine stopped showing the LED light for a while now. It's a 1st world problem but it's annoying when you have no idea what is being recorded unless you check the Recordings bit.
Panasonic 50cx700 sky q 2tb, keep the 3d films, I am still watching those
Re: Sky Q Recording Light not working
Hi @Austinored
Confetti Ring
Avatar for Austinored
Level 6 icon
I've tried that thanks, but still no recording red light
This message was authored by: skywho32
You're lucky! I find the display so irritating I have a piece of cardboard covering it up 😀
