Discussion topic: Sky Q Problem
Message posted on 29 Nov 2025 10:55 AM
Sky Q Problem
My skybox will not retain my broadband settings
Message posted on 29 Nov 2025 12:14 PM
Re: Sky Q Problem
Hi @Sal37
If your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 30 Nov 2025 05:43 PM
Re: Sky Q Problem
I have tried rebooting the router and re-entering the settings. This made no difference. I then undertook a factory reset, but this has not worked either. Everytime I enter the wi-fi settings it works fine, but as soon as I turn the Sky Q box onto standby and then back on again, it looses the connection and settings.
