Discussion topic: Sky Q - Possible Remote Issue
This message was authored by: Mark+Reeves
So on my Sky Q remote only two buttons will work. Of the four directional buttons only the up and down will work. I rebooted the remote by the 7+9 then 1+3 technique, but that didnt help. I brought down the remote from upstairs and it was exactly the same. Then I pushed the reset button the front of the box and an amber ligth came on to the right of the green light, which flashed for twenty seconds or so before going off.  Finally I switched the box off at the mains, waited two minutes and then restarted.  No change.
So I'm stuck watching BBC2, which is fine, but I was hoping to watch some football.
Re: Sky Q - Possible Remote Issue
There is no reset button on the front of a Q box @Mark+Reeves
Sounds like you pressed the WPS button.
Unlikely to be the same issue with 2 different remotes.
Did you follow the procedure exactly to reset the remote.
Avatar for Mark+Reeves
Obviously
@Mark+Reeves wrote:
Obviously
Hi @Mark+Reeves
I edited my previous post so you may has missed the edit
I did follow the instructions on both remotes. The problem is because only two buttons are working I can complete the process.
Did you wait until the  remote control LED flashed 4 times when you pressed and held 7 & 9 together @Mark+Reeves
