06 Mar 2023 05:55 PM
If your router allows it, make the IP address assigned (and working) for Sky Q a static address.
16 Jul 2023 02:25 PM
16 Jul 2023 03:26 PM
I just spoke to HeyB technical and suggested that the default gateway IP address on their Adtran Router of 192.168.1.1. could be the problem as Sky Q cannot resolve that with a UK based IP. After a brief discussion the young lady said she would raise a ticket to assign a new IP address to my router in the hope this will resolvethe issue. In the meantime, Sky have booked me an engineer visit to resolve it as well. If the HeyB action resolves the problem I will cancel the engineer visit that isn't until 27/7.
17 Jul 2023 07:38 PM
192.168.1.1 is just the addres to get to the router from your network it's not the router's IP with the outside world. This is set my Hey Broadband and I've had repeated issues with them over the past 6 months - this being the latest. I had similar issues with Amazon Prime. This, plus the repeated down time in my area, are why I won't be staying with them once my contract is up
17 Jul 2023 08:09 PM
You learn as you go along. Your right about the IP address bring the address to the router bit the specific IP of the router. My colleague told me that Hey B operate aVPN and don't if this addresses MDT not appear to be in the UK mainland. All you need to do is write to support@ HeyB.co.uk and request then to sign aUKVPN to your router and that will solve the problems you've been having and be too.
20 Jul 2023 09:23 PM
Hi all,
I started having the same issue and managed to get it sorted.
I logged in to my router panel and had to release & renew my ipv4 & ipv6 addresses. As soon as I did this I was able to download on demand content without the dreaded location check failed error 😁
02 Mar 2024 03:57 PM
I have had the same issue . Sometimes I can send a request from my phone and it works now and then . I am with your fibre and done all the reboots . Surely it must be a sky issue
24 Sep 2024 08:36 PM
Not worked for me, everything been turned off and on as well
Is there a update ?
24 Sep 2024 08:42 PM
You've deffo rebooted your Dishy ?? You can check your WAN IP by asking Google 'What's my IP address.
28 Sep 2024 11:07 PM
Managed to get a 145 address in the end and it is now working. Sky need to sort out allowing stsrkinks new range asap, we are coming into power cut season, and I do not wish to keep messing with this. 100 % that sky will be gone before I get rid of of starlink , never going back to 1mb
