This discussion topic has been answered Discussion topic: Sky Q - Not connecting to BT Router Network - Check Password
Message posted on 25 Feb 2024 04:03 PM
Have seem this alot on the forum here but never a resolution posted.
Our Sky Q recently lost connection to our BT router.
When we try to try to reconnect with the correct SSID and Password (which is 100% correct) we are just getting a message saying unsuccessful connection : Please check your password and try again.
I have done this many time over the years so know the basic process. Need some specific help with this issue which I have seen many other have had.
This has also knocked out our 2 Sky mini boxes, which is very frustrating.
Thanks in advance.
Message posted on 26 Feb 2024 12:35 PM
The 2.4 was already split out.
However I have had a result.
Although I had tried all manor of reboots and restarts previously I dialled it back to zero.
1. Powered off all Sky eqipment. (Sky Q, 2 x mini, wifi booster) and left it for an hour or so.
2. Rebooted the BT router.
3. Powered up SKY Q only. Selected the 2.4 SSID and applied PW. Low and behold victory, seemed to take an age to connect but it did it !
4. Powered up Sky wifi booster. Waiting for all 3 green lights.
5. Powered up Sky Mini 1. Had to do the reconnection process with main SKY Q box. But worked.
6. Powered up SKY Mini 2. That did an auto connect and configured new IP.
7. Made a coffee !
I can only suggest that the incorrect PW error is a complete red herring for some other connectivity error with the router.
Message posted on 25 Feb 2024 08:11 PM
Re: Sky Q - Not connecting to BT Router Network - Check Password
There is no easy resolution which is why you see it a lot.
I would try doing it with both minis powered completely off.
Message posted on 26 Feb 2024 11:58 AM
@Chodley Thanks for the tip, however powered off both mini's and the Sky wifi booster and I still get the same response.
I am guessing the next step is customer support and I am dreading that experieince before even picking up the phone !
Message posted on 26 Feb 2024 12:08 PM
@Benje just a thought have you tried resetting your router then rebooting your main Q box and trying to connect. If you have then just ignore this post 😁
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 26 Feb 2024 12:14 PM
also worth trying splitting the 2.4Ghz SSID on the BT router to a different name if you can.
7. Made a coffee !
