Discussion topic: Sky advisor just rebooted my router. Now I can't get Sky Q box to connect. Have tried Network Setup
This message was authored by: Libertyloo
Why won't my Sky Q box reconnect to router? I've turned box off and ran the Network setup several times. The router has been playing up so advisor talked me through rebooting it by holding reset button for 30 seconds and turning off at mains for 6 minutes. Help!
Re: Sky advisor just rebooted my router. Now I can't get Sky Q box to connect. Have tried Network Se
Hi @Libertyloo
Assume this is Sky Broadband and you are using WPS as follows:
As you are on Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Avatar for Libertyloo
Thanks for replying. Unfortunately I've followed the Network setup several times, pressing the wps button on router
Hi @Libertyloo
Might be worth resetting the router again and then Box network reset again.
Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
