Discussion topic: Sky Q Mini
This message was authored by: Nat87
Sky Q Mini
After moving our mini box we no longer get signal.
Sky have advised they cannot provide a signal booster and I have to request one from my internet provide.
When I advised we already have a WiFi booster and it is not helping the sky box connect she suggested I get a second one.
is this right, I read that a booster can be supplied even if my WiFi is not with sky. if so any tips on what I can do to get it to connect.
Re: Sky Q Mini
Hi @Nat87
Afraid mini boxes will not connect to 3rd party WiFi boosters.
Sky should be able to provide one to aid Q box connectivity.
You could try try the following to reset the Mini WiFi.
Reboot the mini as above.
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the mini and you will need to contact Sky directly.  Maybe you be may a better response from a different agent.
Avatar for Nat87
Re: Sky Q Mini
Thank you for your response.
After speaking with sky today, they have advised they cannot provide me one as I use a third party for my internet.
Dont know where to go from here.
Re: Sky Q Mini
Hi @Nat87
Did you explain that you need the Sky Q booster to connect a mini ?
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
Avatar for Nat87
Re: Sky Q Mini
Hi,
Yes, we went through loads of different tests and then I was told to just get another WiFi booster from my provider.
Re: Sky Q Mini
@Nat87 wrote:
Hi,
As I said @Nat87
these will not help to connect mini boxes.
Avatar for Nat87
Re: Sky Q Mini
Ok, I will try again tomorrow.
thank you for your help.
Re: Sky Q Mini
As I said in my earlier post @Nat87
I have escalated this to Sky.
Read the previous pist for information
Avatar for Nat87
Re: Sky Q Mini
Thank you so much. I will keep an eye out for that.
Re: Sky Q Mini
@Nat87
Note the key is to emphasise this is a Q television problem, not one with WiFi.
