Discussion topic: Sky Q Mini needs rebooting every day
This message was authored by: stevenM2
I have 1 Sky Q mini box that keeps locking up (nearly every day) it needs rebooting to make it work - This box does not match the serial number of any of those listed on my account but was supplied as part of multiroom by Sky
Re: Sky Q Mini needs rebooting every day
Regarding the serial number @stevenM2
I'm not aware there are any mini serial number shown.
However I've had Sky Q since 2016 and my account doesn't even show that I have 3 minis (all supplied by Sky in 2016)
I wouldn't worry about it.
It you have multiple minis try swapping the problem one with one of the others to see if Location is the issue.
Also try the following;-
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Avatar for stevenM2
Hi Old Fella
I really appreciate your help - everything you have said is as I have carried out - I am an AV integrator and spend most days integrating Sky - frustratingly this is my own house and my 1st experience as the end user trying to get a replacement unit - the good old days when you used to call, get a diagnosis and an advanced replacement sent out! thanks for your help - once again appreciated
@stevenM2 wrote:
Hi Old Fella
Exactly what happened when you swapped the mini @stevenM2 ?
