Discussion topic: Sky Q Mini box
This message was authored by: Bluenosedugarry
Sky Q Mini box
I have main Sky Q box and 2 minis. The second one I have had only 1 week. It no longer allows me to watch sky as it says I am watching too many boxes. Any ideas please
Re: Sky Q Mini box
@Bluenosedugarry
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB non UHD box only allows one mini box to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes.
