Discussion topic: Sky Q Mini box blue screen
This message was authored by: MISFIT1966
Sky Q mini box has been showing blue screen all day, have tried all solutions offered via Sky and on forums, including multiple re-boots, restarting Broadband etc, the messages in settings say the Sky Q-box is connected, and both boxes are connected to Wi-fi.
This is very frustrating, main box is fine, but use the mini box more because of its location, please can Sky contact me asap with a solution for this, thanks.
Re: Sky Q Mini box blue screen
Hi @MISFIT1966
Reboot the mini as above.
Avatar for MISFIT1966
@oldfella thanks, have tried all of those apart from re-booting main box, will give that a go, thanks.
@oldfella it worked! Thanks very much 👍👍
This message was authored by: MichaelSkyCust
I just wanted to say thank you. I had the same problem, but as the main Sky box was working fine I assumed I didn't need to do a reset there. Could have saved a lot of time if I had read this earlier today 😆
