Discussion topic: Sky Q Mini - Disney+ problem
Message posted on 13 Nov 2023 11:41 PM
I have a Disney+ subscription and sky Q with multi room
disney works fine on the main box
on the mini , the app opens , I can log in and I can see the shows etc . However when I open one to watch , the loading circle just spins and spins, eventually erroring
I have checked online and followed all recommended actions (refreshing the apps , updating software ) - nothing works
the Q was only installed 2 wks ago so all hard and firm ware is upto date
I friend of mine also has the indentical issue
please advise
Message posted on 14 Nov 2023 08:39 AM
Re: Sky Q Mini - Disney+ problem
please advise
Hi @KieranGray Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the asme with any Mini boxes?
Message posted on 14 Nov 2023 10:09 AM
Hi @KieranGray
I had exactly the same problem, when I checked the mini was on a really old software version, Q150. I forced a manual software update which brought it up to Q220 which resolved the problem.
