12
This discussion topic has been answered Discussion topic: Sky Q Mini Disconnecting Daily
This message was authored by: Dollysmum2
Between 2am and 6am the mini box either wants to reconnect to Wi-Fi (and constantly fails) tries to update software (and fails) or reactivates the connection to the main box and fails. Every day I have to unplug from the mains, wait, switch back on to get the mini box to reconnect.  Sometimes it can take half an hour to have it working.   Also when returning from a menu to the programme I get a blank screen and no sound for several seconds (also randomly happens).  This has been getting progressively worse for months, but is now daily. Sky installed equipment around 8 years ago and nothing has been moved or changed other than main box swapped two days ago due to isdue with hard drive and problem persists. I'd love to get this fixed!
Re: Sky Q Mini Disconnecting Daily
Hi @Dollysmum2
First check that all your Q boxes are in the same Standby mode
https://www.sky.com/help/articles/using-the-standby-settings
And also on the same Software version
https://www.sky.com/help/articles/sky-software-updates
Hi @Dollysmum2
Avatar for Dollysmum2
Hi @oldfella !
Great suggestions, thank you.  I had checked the software version as soon as I got the new main box, but hadn't checked the standby mode. Having just done that they were both the same 'eco'.
So no changes needed.
@Dollysmum2 wrote:
Hi @oldfella !
Hi @Dollysmum2
Is the mini on the same Software version as the main Q box?
Might be worth trying standby Active or None on both boxes.
If you try None it's necessary to switch the boxes into standby with the remote when not in use.   Don't leave them on all the time
Hi @oldfella
Yes, both boxes were already on the same s/w version and I whilst I didn't need to correct one of the standby modes to match, as they already did, I have switched them both to active.
neith box is left on as they are switched off when the Tv goes off.
Open to any other suggestions that may fix this 😁
@Dollysmum2 check what standby mode your new main box has been swet to if its eco then it will go to sleep between roughly 2 am and 6 am making it seem as though the mini box is not connected you need to set the standby mode on both boxes to active or none
see below
https://www.sky.com/help/home/sky-tv/sky-tv-q/using-sky-q/settings-and-preferences-q-test/standby-se...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Thank you @Laing1,  @oldfella had already gone though this with me.
I've had this mini box for 8 years and both boxes have been in Eco mode for this whole time with no problems until a few months ago. It is now on Active which doesn't resolve the problem and  "none"  is not a preference I want to chose.
Happy to try other suggestions!
@Dollysmum2 wrote:
Thank you , had already gone though this with me.
Hi @Dollysmum2
Have you tried a Reset Settings in the main Q box hidden menu?
Then carry the similar Reset settings in the mini box with the issue.
Hi @oldfella , yes this was done with the previous Sky Q box but as there was a problem with the hard drive this box was replaced a week or so ago. I have just done the same again with this new box so we'll see in the morning whether this helps. Thanks.
Me again!
suggestions haven't fixed the problem. The Mini box now stays on all the time if I don't remember to switch it off when I fall asleep and is hot. This is a worry. What can I do next??
 I had a very similar issue. Daniel0210 gave me an answer which solved my problem. Have you checked in settings whether your main box is set to Active rather than Eco? To check, go to settings, select setup, then select preferences then change Eco to Active. This problem usually happens in the early hours of the morning. Eco is designed to save you money by switching off the main Skybox.
@Anonymous
This has already been suggested in at least two posts above.
