Discussion topic: Sky Q Mini Connectivity Problems
This message was authored by: Itsnotlupus
The two sky q mini boxes show they are connected to main box and network but there is no picture.
Have to unplug and reconnect at least three times a day it's becoming a pain.
Is there a solution engineer coming next Monday.
Installed last Thursday.
Re: Sky Q Mini Connectivity Problems
Hi @Itsnotlupus
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Avatar for Itsnotlupus
The connection drops out and comes back again
