Discussion topic: Sky Q Mini Boxes not working
This message was authored by: Dunc234
I have 3 Sky Q mini boxes and all have stopped working, saying 'Please check your subscription entitles you to view this channel on this box', this is on every channel. I've tried resetting the boxes and the Network connection but they still refuse to work. Any help would be appreciated..
Re: Sky Q Mini Boxes not working
Hi @Dunc234
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
@Dunc234 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Dunc234
@Laing1 @oldfella thanks for the advice, but still not working..
Hi @Dunc234
Try a Reset Settings in the main Q box hidden menu.
