Discussion topic: Sky Q Mini Box not working
Message posted on 08 Apr 2024 09:52 AM
Hi my Sky Q Mini Box won't work. When I switch the Mini Box on at the mains plug the red stand by light on the front of the Mini Box comes on for a couple of seconds and then goes off. I tried turning the Mini Box and TV off at the mains and back on again and also I turned off the main Sky Q box at the mains and back on again but this didn't work. The main Sky Q box is working fine. I turned off the Mini box at the mains then held down the reset button on the back of the Mini box and turned the Mini box back on at the mains and kept holding down the reset button for a minute but this didn't work either. I also just held down the reset button on the back of the Mini box without turning the Mini box off and the red light comes on and stays on but still the Mini box won't work. The only button on the remote control that brings on the red light on the remote is the ? Button and the rest of the buttons do nothing. I tried re pairing the remote to the Mini box by pressing down 7 and 9 and then pressing down 1 and 3 but nothing happens. Do I need a new Sky Mini Box?
Message posted on 08 Apr 2024 10:05 AM
Re: Sky Q Mini Box not working
Morning @SM221,
This sounds like a power supply issue which on the mini boxes is Inside the mini box itself.
I would recoomend you calling Sky and getting a replacement Mini box, the courrier usually do a swap at the door, so you give the delivery driver your old mini box and the delivery driver gives you the new one.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 08 Apr 2024 10:12 AM
Thank you for your reply. I tried ringing Sky this morning first but I couldn't get speaking to a person and the automated service led me to the Sky forum. Do you know the phone number for Sky that I should ring?
Thanks for your help
Message posted on 08 Apr 2024 10:39 AM
Morning @SM221
The way I get through to someone is press the option for im a new customer/join sky tv, explain your issue and they will forward the call to the Relative department.
Message posted on 08 Apr 2024 10:42 AM
That's great thank you for your help.
Message posted on 08 Apr 2024 10:46 AM
Just thought of something though, do you have another kettle lead, figure of 8 lead that you can try incase it's the power cable and not the box
Message posted on 08 Apr 2024 11:01 AM
Hi
No unfortunately I don't have another cable to try. I took the power cable out of the back of the mini box and when I put it back in the same thing just happens the stand by light comes on for a couple of seconds and then goes off. I tried pushing and holding the power cable in and wiggling it about but the light doesn't come on. I will try and get a replacement.
Thanks again for your help.
Message posted on 08 Apr 2024 11:32 AM
@SM221 wrote:
Hi
Hi @SM221
Check the following link and if you cannot solve your issue it will lead to box replacement.
Message posted on 08 Apr 2024 12:32 PM
Hi
I tried all that already and it didn't work but thank you for your reply.
Message posted on 08 Apr 2024 01:24 PM
Hi @SM221
Since the Sky.com page hasn't worked for the replacement Q box I’ve escalated your post our Messaging Team who should reach out to you soon, saving you the need to call in.
Look out for a blue/red speech bubble at the bottom of your forum page. You’ll then have 48 hours to click on it and join the private chat or it will close automatically. If you fail to respond to each chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky aren’t instant so you’ll just need to check the chat thread regularly.
This link explains the Community Messaging process.
Community Moderator
Message posted on 08 Apr 2024 02:00 PM
Thanks for escalating this. We’ve sent @SM221 an invite to chat.
