30 Mar 2023 11:43 AM
Hello,
we had a few power cuts today and after the power came back on, I noticed the Q mini box in the bedroom didn't have the standby light on.
I unplugged it and plugged back in and the red light came on for a few seconds and went off.
It is getting power as there is a light on at the back
If I press the reset button, the red light comes on and stays on but I can't interact with it.
inhave tried holding reset in but nothing happens.
does this seem like it's stuck in a mode or faulty?
thanks
30 Mar 2023 11:48 AM
@Djhannan wrote:
Hello,
thanks
Hi @Djhannan
30 Mar 2023 11:55 AM
Hello
i have followed the link
the red light shows on the remote when I press ?
I have held down the standby button on the box and turned it back, but no light flashes.
As soon as I power it on, the red light goes off after about 2 seconds.
if I press the reset button on the back, the light stays on but nothing happens
30 Mar 2023 11:59 AM
@Djhannan wrote:
Hello
Hi @Djhannan
You need to hold in the reset button in for at least 30 seconds while you switch it on.
If the Recovery doesn't work there is only one option which is shown in the link
30 Mar 2023 12:22 PM
Hello
the link does state standby button, which is the front.
I have just done the same with the reset but to no joy
What is the best number to call for a new box?
30 Mar 2023 12:27 PM - last edited: 30 Mar 2023 12:28 PM
@Djhannan wrote:
Hello
Hi @Djhannan
Just to confirm what the link says regarding the minis
If the lights don't show after 30 seconds, repeat steps 1 to 2. If it still doesn't work, you might need to replace your Sky Q box.
09 May 2023 10:29 AM
Hi there
i am having exactly this problem following a series of power cuts. No lights on front of sky q mini box. When unplugged and then plugged back into mains red light comes on for a few seconds then disappears.
Did the reset button which puts red light back on. Never does it flash red/green despite holding down for 30+secs. Tried unplugging again and red light completely disappears again only returning after pressing the reset button again. The remote is working. Changed the fuse in the plug just to be sure!
Have the power surges from power cuts fried the box? Did you rectify the problem or is it a new box?
many thanks for any help
12 Feb 2024 11:21 PM
Having exactly the same problem following a power outage.. did you get this resolved or is it a replacement mini box.
my other mini box is working fine, so I suspect I do have a broken unit.
25 Nov 2024 10:49 PM
Try repairing your remote. Similar problem and remote not working as well. Reset using 7&9 buttons and point at the box!! Mine just came on.
24 Dec 2024 09:21 PM
I have the same problem...
none of these steps worked!
doni need a new box?
24 Dec 2024 09:24 PM
Re pair the remote. It won't show but it will then get you back to where you want to be with a working system etc.
