9
This discussion topic has been answered Discussion topic: Sky Q Mini Box No Signal
This message was authored by: AH66
Main Sky Q Bix is working, but no satellite signal on mini boxes
Re: Sky Q Mini Box No Signal
@AH66 wrote:
Thanks, but that didn't work. I have 3 mini boxes and they are all the same?
Hi @AH66
When you do the Network  Reset on the minis,   Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Hi @AH66   What exactly is the full message shown on the Mini box?
Hi @AH66
Reboot the mini as above.
Avatar for AH66
No satallite signal
Avatar for AH66
Avatar for AH66
By the way, I'm grateful of your help, but how do you actually get to speak to someone from Sky?
Hi @AH66
To contact Sky
Hi @AH66   I'm afraid that you will need to contact direct. Please see Welcome below for information about this community.
Phone them and don't say anything to the voice prompt system
Have you tried a "reactivate" on the minis?
This message was authored by: Carnbee19
That's the message on the mini box
