Discussion topic: Sky Q Mini Box Morning connection problem
This message was authored by: Russell12
I have 2 mini boxes both about 20 ft and 2 walls from the main box. Main box is 8ft high mini is 4 ft. Most morning the mini has lost connection to the main It will reconnect but then drops the connection frequently for about the first 30 min then works for the rest of the day. When connection to the main box is bad I can still watch Netflix  via the mini. All other internet devices are good routert is Starfix..
Re: Sky Q Mini Box Morning connection problem
Hi @Russell12 In the following order:-Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
