Discussion topic: Remote code for Bose universal remote
This message was authored by Technaudio This message was authored by: Technaudio
I have a Bose solo 15 soundbar, with the Bose universal remote control. Does anyone know the code to pair my Bose remote to the sky stream "puck"? - so that I can use the Bose remote to control the sky stream.
I don't like the sky remote, the "soft touch" texture of it is horrible. I don't use the voice search, so that part is of no use to me.
This really should not be difficult.
This message was authored by Laing1 This message was authored by: Laing1
Re: Remote code for Bose universal remote
@Technaudio i'm not sure if this is possible you could check with Bose if they have a code but as the Glass/Stream remotes are bluetooth then there may not be any code
This message was authored by SlenderRobert This message was authored by: SlenderRobert
@Technaudio
You're probably out of luck unless your Bose remote can 'learn' IR commands.
The Stream Puck remote can be switched from Bluetooth to Infra Red mode and with other 'learning' universal remotes you can then teach them the commands.
I have a Harmony Elite remote with hub and the Stream commands were recently added to its database so I can use it instead of the dodgy rubbery remote that comes with Stream. Perhaps if you badger Bose they may be able to get hold of the correct codes for Stream.
This message was authored by Yatsey This message was authored by: Yatsey
Hi, I just spoke to Bose about this. I have the Bose universal remote, they told me that Sky have a code to use in the Bose UR to control the Q box. Who on earth you would phone at Sky though would seem mission impossible 🙄
This message was authored by J_Tyler This message was authored by: J_Tyler
Yeah, good luck with that!
