Discussion topic: Sky Q Mini Box Connection
This message was authored by: KezzaRed
I have Sky Q along with 4 mini boxes
It's got to a stage now where nearly every time I switch on one of the 4 mini boxes you can hear sound from a programme but it says connecting to Sky Q box. I have to reboot the box each time to make it work. Had Sky Q from the beginning but this is the worst it's ever been
Any suggestions welcome, Cheers
Re: Sky Q Mini Box Connection
Hi @KezzaRed
Try resetting the connection.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Avatar for KezzaRed
Level 4 icon
Cheers for that, I do so if that on a regular basis unfortunately, too many times to keep count 🙄
I don't need or want a Sky Booster either as I have a WiFi 7 router along with 2 WiFi 6 mesh routers, very much overkill to deal with 60gb movie files
hi @KezzaRed
Perhaps you can explain then what each mini is connected to when you carry out a Network reset on each.
Edit I see you edited your post
Your mesh routers are no help in connecting Q mins
Avatar for KezzaRed
Level 4 icon
The mini's don't connect to the mesh they are on static ip's and bound to the main router. They've not really been a problem just more recently and to be fair don't get used that much these days, it's just annoying
is your router a Sky Q router on Sky Broadband @KezzaRed ?
Avatar for KezzaRed
Level 4 icon
No I've been on BT for 4 years and have Asus WiFi 6/7 routers. Like I say not been an issue until more recently and to be fair get the same issues I used to get when I did have a Sky router, noticed no difference at all
Just for info they are on static ip's for Home Assistant
Mmm.  You should be aware @KezzaRed
If using WiFi Sky Q minis will not connect reliably to anything other than the Sky Q mesh.
They will not connect to 3rd party WiFi or 3rd Party WiFi extenders.
The only way to connect Minis to non Sky devices is to have all Q boxes including the main box connected by Ethernet to the same Network devices.
Other then the advice in my first post I cannot help.
Avatar for KezzaRed
Level 4 icon
Spoiler
Yeh thanks for your thoughts and ideas
I've not seen any differences at all whether I've had Sky router/broadband to what I have now. The issues I've had over the years have been the same on both setups. I have had an engineer test it while I've not been on Sky Broadband/router, separate issue, and he said it was working perfect
Like I said just annoying on the odd occasion it gets used
