Discussion topic: Sky Q Mini Box Apps
This message was authored by: Steven+WS
Message posted on 16 May 2025 11:02 PM
Sky Q Mini Box Apps
Under the Apps tab on the menu all the apps have disappeared apart from Sky. Where have they gone? Amazon Prime, Netflix, Paramount, Discovery+ etc
Find out more
Message posted on 16 May 2025 11:09 PM
Re: Sky Q Mini Box Apps
First try a power restart of your Sky Q box;
- Press Standby on your Sky Q remote, then switch off or unplug at the mains and wait for the lights on your Sky Q box to turn off.
- Plug in and switch your Sky Q box back on at the mains.
- Wait for the on-screen instructions to disappear then press Home on your Sky Q remote. Some features may take up to 5 minutes to return.
If a restart did not fix the issue, try a refresh of the apps;
- Press Home on your Sky Q remote, then highlight Settings
- Press 0,0,1 and Select to access the Installer menu
- Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
- Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
More info here;
https://helpforum.sky.com/t5/forums/replypage/board-id/skyq/message-id/699228
Sky Community Superuser. What is a Superuser? Click here to find out
