Discussion topic: Sky Q Keeps Dropping Its Connection
This message was authored by: karenkaren1
My Sky Q keeps dropping off the wii fi, I am on my 4th reset this afternoon 😡
Moderator note: subject of thread updated to better reflect the conversation
Re: Sky W
Hi @karenkaren1
Is that a full Network reset or just a reboot?
Avatar for karenkaren1
Re: Sky W
I am now on the 8th resets  & 2 total reboots
Re: Sky W
Not sure what you mean by a 'reset' and a 'total reboot'. Have you tried restarting your broadband Hub, by switching off at the plug for 30 seconds or so?
Re: Sky W
@karenkaren1 who is your broadband provider and if its Sky what colour of router do you have black or white ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Sky W
Have you completed the following @karenkaren1
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Re: Sky W
I've done all that & im with sky, tried calling them but cannot wait the prodiceted 40 mins for them to answer my call. I am now in double figures resetting my sky Q, everything else that's connected is working fine
Re: Sky W
Did you note the reference to the Sky Max router in my post  @karenkaren1
You have to connect this using SSID and password for the 2.4 Ghz band and not by using WPS
