Discussion topic: Sky Q HDD Error causes Mini box to not work
Message posted on 11 Sep 2024 02:12 PM
I have a Sky Q box that suffered a HDD error. I reset the HDD losing all my recordings and it worked for an hour or so. It then came up with the HDD error again. I could not fix this and just started the box to watch live programs. I then found thet the Sky Q Mini would not work. It came up with a "No Signal" error. I tried everything but have found that it is the HDD error that causdes this to happen. I thought I would post this in case anyone else has this issue and wonders why their Mini box won't work. I have had a replacement Main box and the mini is now happy and working fine.
Message posted on 11 Sep 2024 02:24 PM
Re: Sky Q HDD Error causes Mini box to not work
The mini is a slave to the main box - satellite signals are cached on the hard disk before being sent to the mini. (This is why mini's fail when the main box does)
Message posted on 11 Sep 2024 02:28 PM
There isn't much info on that so I hope this saves someone some heartache!
