Discussion topic: Sky Q Dropping Wifi
This message was authored by: Theyrealltaken
Sky Q Dropping Wifi
I'm getting incredibly fed up of the amount of times that my Sky Q box drops the wifi connection. Other people seem to have the same problem and I've tried various troubleshooting solutions that I've seen on the forum, but nothing has worked.
I have BT fibre with a BT router. Every other device that's connected to it has never once lost connection with the router. I have lost count of the amount of times that my woeful Sky Q box has lost connection.
The only way I can resolve the problem is by unplugging the Sky box and going through the set up again. On average, this is probably once a week.
How do I resolve this? I'm starting to think I have a dodgy box.
Avatar for Theyrealltaken
Re: Sky Q Dropping Wifi
Update: this time round a restart hasn't worked so I can't actually connect my Sky Q box to my wifi.
This message was authored by: Ecosse
I'd suggest fully rebooting both the router and the Sky Q main box.
Unplug both of them, same time, from the wall for at least 30 seconds.
Plug back in the router only, get it up and running, and run a speed test on your mobile.
Now plug back in the Sky Q box, go to settings, and reset the network settings section. Then scan for your router, add in your password, and hopefully, you're back up and running.
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
