Discussion topic: Sky Q Boxes Slow to Change Channel
This message was authored by: KevinEley
My main Sky Q box is very slow to change channels (20-30 seconds) and the mini box is the same and fails to find the channels at all at points, with the picture being a bit hit and miss.
I have reset both boxes and the router but no change.
I dont really know what else to try.
Re: Sky Q Boxes Slow to Change Channel
Hi @KevinEley
When you reset was this just a reboot?
If so
Try a Reset Settings in the main Q box hidden menu.
Avatar for KevinEley
Hi,
Thanks for the reply, however this is the reset I have tried.
Unfortunately it didnt have any impact.
I did read somewhere that resetting the hard drive may help, but I am not sure of the integrity of this.
@KevinEley wrote:
Hi,
If you can afford to lose your Recordings then it's worth trying @KevinEley
It is certainly better.  Will see how it goes.
This message was authored by: Mike+Conyers+1
I had exactly the same issue and tried absolutely everything to resolve it, including changing both the main box and the mini - to no avail. In our setup, it was a non sky broadband provider and router and the main box and mini were both connected via WIFI on 2.4ghz. Everything was working until a few months ago then suddenly the mini was slow to change channels or delete any deleted recordings, I think perhaps a box software update had occured. Even switching the mini on was taking a long time. When experimenting, I noticed that if the 2.4ghz was disabled on the main router, the mini then worked as expected and changed channels fast again. You do need it enabled though for everything to work including streaming, so in the end the thing that worked for me was to re-enable the 2.4ghz connection, then change the security from WPA2 to WPA3/WPA2 on the main router for the 2.4ghz connection. You need to ensure that any changes are saved in the router interface. Once I did this, everything is back to normal and fast to change channels again. Hope this helps.
