Discussion topic: Sky Q Box
This message was authored by: Angie105
Sky Q Box
Had engineer in for TV he explained that Sky box is causing tv to pixelate. Possibly needs replacement box
Re: Sky Q Box
Was that a Sky 'engineer'?
Pixelation on live television is typically an issue with the satellite dish: if there are similar symptoms with on-demand content then it's usually a problem with the HDMI cable.
Avatar for Angie105
Re: Sky Q Box
Engineer said it's the box that's the problem it's very old
Re: Sky Q Box
Hi @Angie105   Strange, I would have expected a Sky installer would have replaced the box while they were with you.
Avatar for Angie105
Re: Sky Q Box
It wasn't a Sky engineer he was here to do the tv it had a backlight problem. All fixed now. I mentioned the pixilation as we only use the tv as a monitor and he's been doing the job for over 20years. He explained it is the sky at fault
Re: Sky Q Box
Hi @Angie105   In that case you need a Sky installer to check your dish alignment. Either way, box or dish you will have to contact Sky to book a visit.
