Discussion topic: Set up a TP link mesh system with part fibre Sky Q router SR 203
This message was authored by: TPMesh
I would like to know how to add a TP-Link mesh system, either BE9300 or XE75 Pro to my part fibre Sky Q router, SR 203. My Sky box is the 2Tb model with one ski-mini Box with a Sky repeater.  There seems to confusion on the Internet as to whether a stable system is possible.  I live in a rambling old house with brick internal walls. Grateful for any help.
Re: Set up a TP link mesh system with part fibre Sky Q router SR 203
Hi @TPMesh   It is not possible to put the Sky router in bridge mode, so any solution will involve double Nat issues. If you know what you are doing then you could replace the Sky router with something like a Draytek Vigor 130. Alternatively, replace the Sky router with TP-Link Deco vdsl routers like the X73-DSL.
Avatar for TPMesh
Thanks MightyQuinn,  I'll look into those options. Thanks so much.
