This discussion topic has been answered Discussion topic: Sky Q Box wifi
Message posted on 24 Feb 2025 07:54 PM
Hi
My Sky Q box once put onto standby disconnects from WiFi. When switched back on it won't connect unless switched off at wall.
Any help would be appreciated.
Message posted on 24 Feb 2025 08:31 PM
@Sammy69287 wrote:
Broadband is through EE. Router is in other corner of room to skybox approx 3.5m away.
Have you carried out a Network reset on the Q box @Sammy69287 ?
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 24 Feb 2025 08:23 PM
Re: Sky Q Box wifi
@Sammy69287 wrote:
Hi
Hi @Sammy69287
Who is your Broadband supplier and where is your Q box located in relation to your router?
Message posted on 24 Feb 2025 08:27 PM
Re: Sky Q Box wifi
Message posted on 24 Feb 2025 08:50 PM
Re: Sky Q Box wifi
Thanks appears to have worked.
