Discussion topic: Sky Q Box wifi and hardwired
This message was authored by: aferns
My Sky Q Mini Box is usually hard wired to my BT Hub Router.  But for some reason the Sky Q mini box stopped connecting to the BT Hub, so I have had set up one of my Sky Q mini boxes using wifi!
My question is how do I turn off wifi on the affected  sky Q mini box and use hard wired connection instead?  I have a  Netgear Switch which connects all my Sky boxes to this!
Re: Sky Q Box wifi and hardwired
Settings
Set up network again from scratch to use ethernet
Special installer menu
disable wifi
Hi @aferns
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go immediately into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on all minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go immediately into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
Avatar for aferns
Level 3 icon
 Sky
I just need to know how to turn of wi-fi for ONE of my Sky MINI boxes and reconnect using ETHERNET CABLE?  All my  3 sky boxes are hard wired to my BT HUB using my Netgear Switch.  How do I check if one of my Sky mini boxes is hard wired or using wi-fi?
it.
@aferns wrote:
 Sky
This is not a route to contact Sky.
However, the answer you are looking for is on the post before yours?
