Discussion topic: Sky Q Booster Boxes
This message was authored by: AJ31
Sky Q Booster Boxes
Hi,
I have Vodafone Broadband.
For Sky I have 1 main sky box, 2 mini Q boxes and 2 boosters. I now have all my Sky boxes connected back to my router via ethernet cables.
Do I still need the Sky mini booster boxes or are they not required due to the ethernet connection?
Re: Sky Q Booster Boxes
@AJ31 wrote:
Hi,
Hi @AJ31
When all boxes are connected by Ethernet you can then switch off all Q box WiFi.  No boosters are required.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router (or Sky router if on Sky Broadband). Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects immediately go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected immediately go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
